SS-V: 2090 Triangular Wing - Fixed Vibration
Test No. VM10Perform a normal mode dynamic analysis of a fixed right triangular plate.
Definition
The plate is 6 in long and 0.034 in thick.
The units are IPS.
- Properties
- Value
- Modulus of Elasticity
- 6.5e6 lb/in2
- Poisson's Ratio
- 0.3541
- Weight density
- 0.06414 lb/in3
- Mass density
- 1.66128e-4 lb-s2/in4
Results
Reference | SimSolid | % Difference | |
Mode 1 [Hz] | 55.900 | 55.710 | -0.34% |
Mode 2 [Hz] | 210.900 | 209.940 | -0.46% |
Mode 3 [Hz] | 293.500 | 290.660 | -0.97% |
